B single bottom plow
RZ
02-02-2006 11:06:09
We have a single bottom plow for a "B" but dont know if we have all the parts to mount it. Would anyone have a diagram of how it should mount. It would sure be a lot of help! Thanks
RZ
02-03-2006 05:51:18
 Re: B single bottom plow in reply to RZ, 02-02-2006 11:06:09
I'm sure we have the manual lift by looking at the picture. We dont have the front drawbar and Im not real sure how the lifting lever is mounted but this is a big step in the right way. Thanks RZ
Rod (NH)
02-02-2006 15:44:53
Hi RZ,
Do you have enough parts to tell if it is a manual lift or hydraulic lift version? I'm assuming it's a standard AC single bottom mounted plow (part of the two-way pickup plow installation) and not an aftermarket arrangement. If it's the manual lift version, the following is a diagram from the AC plow manual. Click on the thumbnail to bring up a larger view. The parts that are numbered are for the manual lift mechanism. The others are common with the hydraulic lift arrangement.
third party image
third party image Rod
