Allis C Pedestal
Toby Wellborn
02-01-2006 06:41:28
Can anyone answer the following question(s) about a 1948 Allis "C" pedestal that i'm rebuilding?
Which way should the upper oil seal be placed in the pedestal?
Should the lower steering bearing in the pedestal be packed with grease prior to installation?
What is the weigh of the gear oil that needs to be used in the pedestal where the steering gear is located?
It looks like the lower steering bearing is not lubed bt the gear oil, but by the grease the bearing is packed with. Is this correct?
Thanks for any Help!
Russ1
02-01-2006 11:30:25
 Re: Allis C Pedestal in reply to Toby Wellborn, 02-01-2006 06:41:28
The upper seal goes in felt side up.
The lower bearing needs to be packed like a wheel bearing since it is not lubed by the oil in the gear box.
The lube oil required is 90W.
Tob y Wellborn
02-01-2006 11:40:02
 Re: Allis C Pedestal in reply to Russ1, 02-01-2006 11:30:25
The new seal is a new Nation seal whih is rubber... Not Felt
