E-Bay WC
mike smith
02-01-2006 04:28:53
Guy on E-bay posted a WC for sale with ser. No. B24BA or RA. Can anyone give me info on this tractor. Stated it was WW tractor but ssaid it had electric start. Any help is appreciated.
Aaron SEIA
02-02-2006 16:07:26
 Re: E-Bay WC in reply to mike smith, 02-01-2006 04:28:53
That is a WW2 WC. I'd have to check some stuff, but I think they still had the electric start during the war. That started in 38. Hood looks ok, fenders and rims are junk, stated the block was broke. Might be able to save the rods, crank, cam, etc. Blocks aren't too hard to find. Rims and fenders aren't too bad either. I think it'd be neater than all get out to see a wartime WC restored with the cultivators on it. They are missing a few parts, but if you post here and the other AC page, you'll find someone that'd just about donate them to you to save them being scrapped. Wonder what his reserve is?
Aaron SEIA
Brad Wright of MO
02-01-2006 13:34:49
Heres what I found.
Allis Chalmers
WC
Manufactured: 1933 - 1948 Total built: 178,202 Factory: West Allis, WI Cost: (US Dollars) $1,341 (1947) Power: Drawbar (HP): 12 - 18 Belt (HP): 21 - 27 Plows: 2 Engine: Manufacturer: Waukesha Fuel: gasoline Cylinders: 4 Bore/Stroke (inches): 3.625x4.5 Displacement (ci): 186 Compression: Rated RPMs: Torque (ft-lbs): Firing order: Oil capacity (qts): Used on first 25 tractors built Engine: Manufacturer: Allis-Chalmers Fuel: distillate Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 4.00x4.00 Displacement (ci): 201.1 Compression: 4.2:1 Rated RPMs: 1300 Torque (ft-lbs): Firing order: Oil capacity (qts): Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 4.00x4.00 Displacement (ci): 201.1 Compression: 5.0:1 Rated RPMs: 1300 Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: sliding gear Forward: 4 Reverse: 1 Capacity: Fuel (Gal): 15 Aux. fuel (Gal): 1 Cooling (Qt): 16 Tires: Ag front: 24x4 steel Ag rear: 40x6 steel Ag front: 5.50x16 Ag rear: 11.25x24 Dimensions: Weight (pounds): 3,300 Wheelbase (inches): Length (inches): 136 Width (inches): Height (inches): 63 Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps: Nebraska Test: Test Number: 223 Test Date: May 1934 Engine: 201 distillate Belt HP: 21.5 Drawbar HP: 14.4 Max pull (pounds): 1,735 Nebraska Test: Test Number: 303 Test Date: May 1938 Engine: distillate 201 Belt HP: 25.5 Drawbar HP: 20.4 Max pull (pounds): 1,841 Nebraska Test: Test Number: 304 Test Date: June 1938 Engine: gasoline 201 Belt HP: 29.9 Drawbar HP: 24.2 Max pull (pounds): 2,198 Serial Numbers: Location: Differential housing 1933 1 1934 29 1935 3127 1936 13870 1937 31784 1938 60790 1939 75216 1940 91534 1941 103517 1942 114534 1943 123171 1944 127642 1945 134624 1946 148091 1947 152845 1948 170174
