Implements for Allis Chalmers 2 point hitch ?
TexasBuckeye
01-31-2006 21:46:24
I"m looking at buying an older tractor and have found an Allis Chalmers WD45 with a 2 point hitch. My question is how hard is it to find implements, i.e. Box blade, post hole digger, mowers or bush hogs that will work with the 2 point system.
Kelly MT
02-02-2006 20:48:47
 Re: Implements for Allis Chalmers 2 point hitch ? in reply to TexasBuckeye, 01-31-2006 21:46:24
I found a good snap coupler auger at an auction last year for $75. Works real good, kind of a pain to hook up. PK
Brad Wright of MO
02-01-2006 13:31:58
I believe it would be much easier just to convert to the 3 point hitch. It will save you hassle in the long run.
John (MO)
02-01-2006 08:49:09
It all depends on your area, there are lots of Snap Coupler implements still around my area. The hitch system was called Snap Coupler, not 2 point, which I believe was an IH or Farmall hitch. It's very simple to put a 3 point conversion on the snap coupler draw bar of most AC tractors so that you can use either snap coupler or 3 point implements. Snap coupler implements are much easier to hook up than 3 point and in my opinion are better designed at least for ground engaging implements like plows. Good conversions run around $300. and I think Cross Mfg. makes about the best.
JMS/MN
02-02-2006 15:02:37
 Re: Implements for Allis Chalmers 2 point hitch ? in reply to John (MO), 02-01-2006 08:49:09
Farmall called their two-point system a "Fast Hitch". I agree that the AC system is easier to hook up to than a 3ph. Many times we hooked the 3-16 plow to the WD45 without getting off the tractor- just back into the Snap-Coupler, lean over to hook the lift arm latches, and go.
ken choquette
02-01-2006 21:00:19
Actually it's Allis's version of a three point hitch.
I have new conversions from AC three point to Standard 3 point. $390. I also have snap coupler 3 14 plow, 8' and 10' snap disc and snap 6' and 7' blade for WD 45's
Ken Des moines.
Mike SE MN
02-06-2006 17:35:12
 Re: Implements for Allis Chalmers 2 point hitch ? in reply to ken choquette, 02-01-2006 21:00:19
I see you have cnap coupler implements. What is the going price for a 3 bottom plow and disc for my WD 45?
Tony Carbaugh
01-31-2006 22:22:57
Texas!!!!! It would be easier to just put a 3point hitch on the old girl. Then you can just round up equipment anywhere. Tony
