BDrive Shaft U-Joint??
Pappy
01-30-2006 21:38:32
Question?? On a 1939 "B" Allis, can the universal joint in front of the transmission be replaced without replacing the whole drive shaft up to the clutch???
Pappy
02-01-2006 13:33:43
 Re: BDrive Shaft U-Joint?? in reply to Pappy, 01-30-2006 21:38:32
Thanks for the responses. This is my first orange tractor and I have a lot to learn.
Tom Davison
01-31-2006 09:35:01
I believe the u joint arrangement was changed to the solid shaft when the CA came out. My 53 B has the solid shaft.
I believe the u joint was better. The shaft uses a coupling like the one on the WD PTO shafts. This is okay, but it has more play in it, and it "bangs" the transmission whenever there is a torque reversal. This is real noisy in my CA. My CA now has transmission problems, and I believe the solid shaft arrangement is the cause.
Has anyone else noticed this or had a similar experience. By the way, I did not purchase a shaft, but I did purchase the coupling, and I believe it was $125.00 a few years ago.
Tom Davison (Pennsylvania)
Jerry Coulter
01-31-2006 07:47:12
According to the parts book, the u-joint became obsolete and is replaced by a later solid shaft w/o joint.
