never did get straight answer WD or WC
kwahl1
01-29-2006 09:44:41
Got a WD engine and a WC or WF Transmission in looking at the forum and the manual. Is this possible? Looking at the diagram for the trans, it has the stickshift, bent at the bottom as it goes into the trans. boot, along with the "reverse latch rail" along side the shift lever. The trans. is slightly a different color than the engine and the starter is on top of the transmission. See next post. Starter Problemo
JMS/MN
01-30-2006 14:03:54
 Re: never did get straight answer WD or WC in reply to kwahl1, 01-29-2006 09:44:41
The straight answer is in the tractor serial number- not any casting number. Serial numbers are STAMPED into the tractor when they are put together. When parts are cast, no one knows when they will be used, so they certainly don't ascertain any date of manufacture. If you have a tranny and lever as described, it is not a WD. Either a WC or WF, at least up to that point of the tractor. Maybe you have some morphodite that someone put together from various parts- something AC never made. But if you have a shift lever with the reverse release lock, it is either a WC or WF tranny. WC, WF, WD engine blocks look the same. If it has an AC differential, the serial number is stamped there. Post a picture.
old
01-29-2006 11:03:47
As I said in the other post the engines are the same other then casting numbers which tell you or can tell you the age of the engine. Also a WD-45 eingine will also fit and bolt right in/on to a WD or WC. On a WD the tranny is part of /bolted to the rear end and on a WC the tranny is bolted to the bellhouseing with a tube going back to the rear end.
old
01-29-2006 10:07:29
The WD and WC engine are the same.
Texas Denny
01-29-2006 10:14:28
 Re: never did get straight answer WD or WC in reply to old, 01-29-2006 10:07:29
Agreed! But some folks (only a few) know how to interpret casting numbers which give a clue to age.
old
01-29-2006 11:00:11
 Re: never did get straight answer WD or WC in reply to Texas Denny, 01-29-2006 10:14:28
Very true, I was going to post more when I did that but had some one come in to pick up a piece of equipment so I had to cut it short. LOL
Texas Denny
01-29-2006 10:02:15
I feel like I must have come late. Can't understand what you mean by "never got a straight answer".
Both the WD and WC have starters on top of the bell housing. On a WC or WF, the battery cable attaches on the left side. On a WD and WD-45, the cable attaches on the right.
To almost all people, a WC and WF engine are indecernible from a WD engine.
As you describe it, the whole works sounds WC or WF to me. There are pictures in the Galleries section under "Tractor Photos". They should be helpful in identification.
