WD45 Govenor Repair
Hossman
01-28-2006 15:35:53
Can anyone offer some suggestions on trouble shootin the govenor on my 55' WD45. It runs and idles good but seems to over rev at full throttle, also there dont seem to be a lot of throttle range. I tried the ol test where you run uphill in a higher gear and have throttle at about half speed, then I opened up hand throttle and there was more throttle left. "There aint suppose to be if govenor is workin as it should have already opened up the carb" Anyhows any suggestions on the matter would be aprec. Thanks
Hossman
01-29-2006 16:04:28
 Re: WD45 Govenor Repair in reply to Hossman, 01-28-2006 15:35:53
Yes have done carb rebuild and butterfly didnt seem to be (sticky) am pretty sure its gov. or "maybe linkage" but I will tackle the gov. overhaul in a couple days as I am waitin on front oil seal to come in from dealer and will change out it first. Do you fellers know will I have to retime ignition after pullin gov? Thanks again for the suggestions.
bw in mo
01-29-2006 05:40:56
Hossman, have you rebuilt the carb if so check the throttle butterfly could be stickey, had that to happen to me either full throttle or idle no inbetween. It don't take much drag on the butterfly.
Jr64
01-28-2006 19:14:43
The only fix I've found is new governor weights and pins. Had a slow governor on mine. I checked the "slop" in the weights and pins. Didn't seem like much, but after replacing them, it made a world of difference.
