Allis B, Coolant in oil!!
Bruce Petrie
01-27-2006 11:53:11
I have a "47" Allis Chalmers "B" with a problem of coolant in the oil. Only leaks or should I say I only notice the problem after it has been sitting for a couple of months. Last year I changed the head gasket and had the head and engine checked for cracks. But this year I have the same problem. The only thing I can think might be bad are the sleeves. Am I overlooking something. PLEASE HELP !!!
Bruce Petrie
02-03-2006 06:03:49
 Re: Allis B, Coolant in oil!! in reply to Bruce Petrie, 01-27-2006 11:53:11
Thanks to all that replied. I did apply 20# of pressure to the coolant system and found leaks @ sleeve seals. I am doing a complete overhaul. Thanks again....Bruce
Butch(OH)
01-27-2006 17:27:29
Some good advise below, Id stay away from stoppem up leaker unless you absoluty cant have the tractor down at this time or only have $5 to spend. The cheapest and least aggravating way to repair it is to know where it is coming from before major dissasembly and that only requires that you leave the coolant in the radiator and remove the valve cover to look. If you see nothing remove the oil pan. Anywhere that water can leak from is visable from these two areas.
Andy in PA
01-27-2006 16:24:38
Bruce, drop the oil pan and check around the sleeves. I had the same problem on my B. Turned out to be the O rings on the sleeves were leaking. You may have to lay there awhile to see as it is a small leak.
gene (missouri)
01-27-2006 16:22:03
If it's not the freeze plugs it could be the "O" rings at the bottom of the sleeves/cylinders.
A cheap fix. Bars block and head gasket seal. Works in antifreeze. Available at most autoparts store.
Install the block seal following the instructions. Change the oil and filter immediately after following the instructions.
Gene
Archie
01-27-2006 14:16:07
Hi Bruce. I have a WD it got coolant in oil. The freeze plugs in the head had very small pin holes in them. Take the hood off and the valve cover off. Might see some on top of head. Good luck. Archie
old
01-27-2006 12:22:51
Might also be a sleeve seal it it has seals that is, not sure on that engine.
