Fairbanks Magneto Timing Internal
L.Lamp
01-26-2006 10:34:47
I have rebuilt a FMJ magneto but am unsure of the rotor gear timing in relation to the impulse drive dogs. Also with the mag ready to fire #1 cylinder, what position should the drive dogs be in. I have to crank it amyway so it would be less trouble with a mag.
Glen in TX
01-27-2006 12:30:15
 Re: Fairbanks Magneto Timing Internal in reply to L.Lamp, 01-26-2006 10:34:47
Your mag should turn CW facing the drive end so line up the C mark on fibre rotor gear with indented mark on steel gear.
Duey (IA)
01-26-2006 15:25:54
Timing a mag. (FMJ)
1. If you have taken the Mag. apart, the internal gears need to be timed. (Set points at .020)
2. Remove the large cap and line the C mark on the fiber gear with the marked tooth on the steel gear. Tip- turn the engine backwards to get the steel gear tooth to stop straight up and position the C mark on the fiber gear straight down. This times the rotor to the points. It is pretty simple in theory. Like all four cycles, the piston comes to TDC (top dead center) twice for every time the magneto or distributor rotor goes around. ("B"&"C")The left side of the engine has a hole in the bell housing where you can see the timing mark on the flywheel. ("WD" &" WD45" The timing mark is found by looking under the flywheel housing for a small hole possibly covered by a small plate held with two wing bolts. The FIRE mark and the TDC mark are located on the flywheel through this hole. Use a little light colored paint to make seeing them much easier). 3. Take out the #1 spark plug, and put your thumb over the hole while hand cranking the engine(best to have all the plug wires off while doing this so the tractor doesn't try to fire) , the cylinder will force air past your finger on the compression stroke. (The other FIRE is the exhaust stroke and has the exhaust valves open so no air will come out of the plug hole).
4. When you feel the air coming past your thumb, look for the FIRE mark on the flywheel. When this mark is centered in the hole, the rotor on the mag should be just lower than the #1 lug on the mag. Looking at it as a clock, #1 lug should be near 10:00. Just before the lug is a plastic stud called the timing stud. Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole. 5. If your rotor points to 5:00 your mag is 180 degrees off and needs to be removed and the coupling turned till you achieve 10:00. If it is not right on the timing stud, you can loosen the mag and rotate it until it is. 6. Put it all back together and time your spark plug wires 1-2-4-3 clockwise on the magneto cap.
Remember if the rotor is aligned with the timing lug when the fire mark is in the window, you got it right. If it's not quite aligned when the fire mark is in the hole, then you rotate the mag clockwise or counter clockwise until it is. Remember Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole.
Bob
01-26-2006 12:16:23
There will be marks on the internal gears, "C" for "Clockwise", and "A", for "Anti-clockwise".
The impulse trips when the lugs are horizontal.
L.Lamp
01-26-2006 10:36:39
This is for a C Allis.
bjb in Ne
01-26-2006 11:36:12
 Re: Fairbanks Magneto Timing Internal in reply to L.Lamp, 01-26-2006 10:36:39
I believe timing a C is the same as a B. With the #1 cyclinder on the compression stroke and the fire mark on the flywheel visable through the side of the tractor the drive lugs on the mag should line up fairly close if the mag is set to fire on #1 as well. The the mag can be fine tuned by rotating it and lining up the rotor tip with the correct corresponding marks located on the upper left side of the mag when viewed with the cap off.
