Hookin' up the43 plow
Charlie
08-07-1999 10:42:49
I've got a 41 B. I found the plow for it but I am not sure how to hook it up. It is mounted on this question mark ? looking deal. It would appear that the front end of the plow attaches with a pin to the piece that is controlled with the hand lever under the tractor while the two other points would be hooked to the hydrolic bar behind the seat. So far so good ....but I've also got that drawbar sticking out behind the wheels which seems to be in the way.Do I have to remove the drawbar or what?
What I really need is some pictures or diagrams cause I don't read so good!
Bob Wild
08-07-1999 19:41:11
 Re: Hookin' up the43 plow in reply to Charlie, 08-07-1999 10:42:49
Yes, you need to remove the drawbar. You have either a No. 5 Series (the earlier version) or a B/C Plow. The No. 5 has a curved bar that fits under the tractor and which the front of the plow hooks to. The B/C Plow has a square frame that goes under the tractor. I have a copy of the Setting up Directions (with diagrams) for the No. 5 Series that I could make a copy of, but it wouldn't be much use for a B/C Plow. E-mail if interested.
