WD radiator
Bob B. in Mn
01-25-2006 10:37:42
I recently removed the radiator but there was so much crud, oil, etc. that I couldn't tell if there was or should be any webing between the radiator and tractor frame when I reinstall it. Anyone have an answer?
Thanks for any help you have.
Bob
chalmersbob
01-25-2006 17:52:26
 Re: WD radiator in reply to Bob B. in Mn, 01-25-2006 10:37:42
yes there is a webbing strip between the radiator and the support. BOB
Bob B in Mn
01-26-2006 14:53:35
 Re: WD radiator in reply to chalmersbob, 01-25-2006 17:52:26
Is this the same webbing that is under the gas tank strap? Where can you purchase this material?
JMS/MN
01-26-2006 17:22:47
 Re: WD radiator in reply to Bob B in Mn, 01-26-2006 14:53:35
I have some webbing from GI cans- looks very similar, maybe somewhat thicker. Check Army surplus stores.
Punchie
01-25-2006 16:53:54
HI Bob
I'm not sure But I would get an old inter tube and double fold it and place it between the two parts just to be safe. Or if you think it may not fit cut small squares and you can use rubber glue to hold them together.
Have a Good One !!
Teddy
