Proper Oil Pressure on a B
Village Blacksm
01-24-2006 14:48:07
Just about to get the "B" ready to run. Have ordered a new oil gauge. Question?? What would be the correct oil pressure for a "B" engine??
(Using an external SW gauge for testing)
Thanks for your input!
steve(ill)
01-24-2006 19:39:11
 Re: Proper Oil Pressure on a B in reply to Village Blacksmith, 01-24-2006 14:48:07
a new motor will put out 15-18 psi with 10w30 at ambient temp. when hot you will still get 15 psi. an older motor with a quite some wear might have 5 psi at idle and 10 psi loaded. if you dont get 2-3 psi at idle, you are looking for trouble.
JMS/MN
01-24-2006 14:57:22
AC engines of that era run low- 5,7,10, etc.
