HP of a Gleaner E engine
JBF
01-24-2006 09:33:04
Looking for the HP of the gleaner E engine. Going to use one in a wd45, also looking for info on easy ways to increase the hp of this motor without large amounts a machining required.
legn4
01-24-2006 19:07:32
 Re: HP of a Gleaner E engine in reply to JBF, 01-24-2006 09:33:04
Will work fine. Done it in a D17,WD45, & WC. You need tochange the front gov assy.Or it will only idle or run full throttle. Also loose fuel pump & cover up hole.Replumb 1 oil line. It is a easy change out. Eddie
Dale Garver
01-24-2006 18:41:33
A friend dynoed one last fall and it had 53hp It is a stock E gleaner with electronic ignition
D17JIM
01-24-2006 14:16:41
i AM SURE THAT IS A 226CI LIKE THE d17'S,WD45'S AND IT SHOULD WORK. I HAVEN'T SEEN IT BUT IT SHOULB BE ADAPTABLE . I HAVE SEEN THEM IN D17'S. IT'S NOT THAT MUCH MORE HP THAN THE 45'S HAD ANYWAY. I'LL BET SOMEONE ON THIS FORUM HAS DONE IT. (SORRY ABOUT THE CAPS)
Brad Wright of MO
01-24-2006 13:37:13
I think that an engine out of that combine would be a little big for a wd45
