6070 hydraulic problems
T Shatto
01-23-2006 21:24:03
For the past couple of months, the hydraulics on my front end loader are "chattering" when I raise the bucket. Recently, the bucket tilt position will not hold and it wants to rotate down unless I keep pressure on the control. Where should I start to look for the problem? None of the lift or bucket tilt cylinders are leaking. I'm thinking the problem may be in my control valve body. Any help would be appreciated before I start tearing this thing apart!!!!
Brad Wright of MO
01-24-2006 13:27:04
 Re: 6070 hydraulic problems in reply to T Shatto, 01-23-2006 21:24:03
First I would check to see if you have enough hydraulic oil in your tractor. Then rebuild the cylinder that is sputtering. It dosent take long but it could work.
