wd oil leak
Carlos IOWA
01-23-2006 19:45:01
Just purchased my first ac.# 199912. Its a wd45 with a wd engine. Finally got it to run after sitting 2 years, It seems to run ok but is dripping oil from front of oil pan by crank pulley, also from rear of pan by inspection plate. Can this usually be fixed by just pan gaskets or do i need to tare into it more. I want to try and get parts before starting this project.
Texas Denny
01-23-2006 21:46:50
 Re: wd oil leak in reply to Carlos IOWA, 01-23-2006 19:45:01
I doubt that either is a pan leak. Seals probably deteriorated while sitting.
JMS/MN
01-23-2006 20:49:44
You need to further identify the source of the leaks. Front of oil pan, or by the crank pulley- two different spots. Same with the rear leak. Front crank seal can be replaced without pulling the engine, rear seal needs the engine pulled. Pan leaks can be taken care of by just pulling the pan.
