WD45 timming marks on thr front of the engin
vjd
01-22-2006 17:11:59
On a WD45 the crank shaft mark and the cam mark come to gether when you turn it around what mark do you use to time the the dist? There is a mark on the dist.but it dose not line up with any other mark on the cam wheel? I am just now taking the engin apart and want to be sure I put it back togeather.It did run be for I took it apart this far
Dave Grubb
01-23-2006 08:51:25
 Re: WD45 timming marks on thr front of the engin in reply to vjd, 01-22-2006 17:11:59
I would bring #1 piston up on the compression stroke, line up the 'F' mark on the flywheel with center of the window, mark the distributor housing inline with the rotor tip.
