WD starter
Play farmer
01-21-2006 19:35:49
Hi guys,
I just got my project WD put together. I put a WD 45 crank in it and one new piston and sleeve. I Did make sure all pistons were the same as the one I ordered. Appeared to be similar clearance from top of piston to top of block as with the original WD crank. Anyway, now it seems that it has too much compuression for the starter. Can I do something to get more power from the starter. It is already on a 12 volt battery. I know some of the pullers put very high compression pistons in, how do they turn them??
Thanks
Kip[UT]
01-23-2006 06:42:27
 Re: WD starter in reply to Play farmer, 01-21-2006 19:35:49
When you say FLATTOP WD45 pistons you have found your problem. You do need to use the proper "crater" style piston w/ the 41/2" 45 crankshaft, as the flattops like the WC & WD used with the 4" cranks will just make too much compression.
Kent of SW MO
01-22-2006 16:39:41
You CAN NOT use WD pistons with a WD-45 crank. The compression ratio will be to high to crank with the stock starter. This is an old tractor pulling trick. If you pull start this tractor it will run and have a lot of power but the starter will not crank it.
Kent
old
01-21-2006 20:58:36
As John has said but he left out one thing. Is that the starter that was on it before you rebuilt the engine?? If so then think about it, rebuilt engine but not a rebuilt starter. How long has it turned over the old engine?? Its probably got the same problem the engine had, its weak and wore out and need the same TLC.
John T
01-21-2006 20:03:22
Farmer, regardless if a starter is in perfect condition, it can only develop so much horsepower and starting torque period, so it may not be able to crank the engine as well as you would like. Things that may help improve its performance are to have the highest rated CCA and Amp/Hr battery (or combination of dual batterys) that physically fits in the compartment, use 00 Gauge Battery and Starter and Ground Cables, and possibly tie the ground cable right on or close to the starter as possible.
John T
chalmersbob
01-21-2006 19:52:51
did you squirt oil into each cylinder before you tried to start it? can you turn it over by hand?
bob
Play farmer
01-22-2006 18:17:39
 Re: WD starter in reply to chalmersbob, 01-21-2006 19:52:51
I did lube it good before reassymbly. I can turn it by hand with a screw driver on the flywheel teeth. It seems as loose as any normal engine like this. I am aware that I cant use WD pistons. I ordered a new wd45 flat top piston and sleeve. The original pistons were dished. I turned down the edges so that they were the same height as the new piston. I even got one a little too short. I think the new one was listed as a high compression but was made for the tractor.
