got my D17 back together...
BCnT
01-20-2006 15:37:11
and fired up today and the POS blew head gasket AGAIN!
this tractors fixin to be on a slow boat to china...literally
Texas Denny
01-23-2006 13:15:27
 Re: got my D17 back together... in reply to BCnT, 01-20-2006 15:37:11
It sounds like a warped head. It's pretty easy to check on a milling machine with a dial indicator.
That idea about the bolts bottoming out is worth checking. Could be the threads at the bottom aren't clean and stopping the process.
Tramway Guy
01-22-2006 06:23:50
Are you sure the bolts are not either bottoming out, or maybe the threads are damaged....so that you might be getting the right torque readings, but they are not squeezing the gasket properly?
jefflaex2
01-22-2006 04:06:45
Yep...sounds like the head and/or block is warped...or the machine shop didn't do a good job. Mine was so bad that I could tell with the edge of my builder's square (B4 shop).
gary case
01-21-2006 12:12:03
man i feel for ya BCnT SOMETHING SOUNDS WARPED. gary
