ms tsx-464spring ?
joel heaton
01-20-2006 09:23:46
third party image
can someone exxplain how this spring goes on to the needle and is supposed to hold up the float on this ms carb. Its from a WD45. does it attach to the needle? is it needed?
thanks Joel
Glen in TX
01-20-2006 22:33:30
 Re: ms tsx-464spring ? in reply to joel heaton, 01-20-2006 09:23:46
You can use it if you want. It's a good idea to use it with the rubber tipped needles. It clips onto the float lever and pulls the needle down and open when float lowers so needle doesn't stick shut in the seat sometimes.
John (MO)
01-20-2006 10:24:25
It clips on to the blunt end of the needle, there is a grove that it fits in. Yes it has to be there. The float holds it and when the carb bowl is full, the float is up and pushes the needle into the seat closing it and stopping gas flow.
