wc side muffler
Rosco Sywter
01-19-2006 19:04:12
is the oval short muffler that goes on the side exhaust manifold still available? where can i find one? how hard is it to patch up the hole that was cut in the hood for the vertical exhaust? TIA
CHALMERSBOB
01-20-2006 18:50:30
 Re: wc side muffler in reply to Rosco Sywter, 01-19-2006 19:04:12
I DON'T THINK THE SIDE EXHAUST USED A MUFFLER
BOB
Texas Denny
01-20-2006 06:50:23
Seems like an odd setup. Did you replace the hood or the manifold?
The hole can be patched. I've done it where someone cut a new hole (for some unknown reason) by getting the right guage or thicker steel and placing it underneathe the hole. Shape the steel to exactly match the curve of the hood. Using a wire feed welder on low power, weld the two together. You won't be able to get a bead but will need to spot it every half inch or so. Then grind down the the high spots on the weld and round (break) the edge of the hole. Use a good quality body filler to bring the hole up to the level of the hood. Sand filler and reapply in low spots. Repeat as necessary. Prime when smooth with no indication of original hole.
It would be a lot easier to get a new manifold that goes out through the top. Those mufflers are cheap and easy to get.
Don't know where to get the side exhaust muffler.
