WD serial number
Kelvin
01-16-2006 20:12:44
Bought a WD last fall and it ran poorly. No power, hard to start. Turns out someone had put the mag on 180 off. Once I got the wires on the right plugs it starts and runs great. The guy I bought it from said it was a 1949 but I can't find the serial number anyplace. Some say on the brake cover and others say on the back of the transmision. No luck. Any suggestions where I might find the serial number?
Kelvin
01-17-2006 20:41:05
 Re: WD serial number in reply to Kelvin, 01-16-2006 20:12:44
Thanks guys. After I scraped 6 layers of paint I found it. It's a 1950 WD. Thanks again.
big jt
01-16-2006 21:41:58
WD and WD45 serial numbers are above the platform on the rear of the left brake housing near the top but facing the rear.
Don't look for a plate you won't find one. Number is stamped into the casting.
hth
jt
old
01-16-2006 21:10:26
Look on the rear axle behind the plat form and you should see the #s
