WD
Martin Miller
01-16-2006 15:19:01
I just bought an Allis WD serial #67640 which would make it a 1950 correct? Also was wondering the horsepower of a WD? Thanks in advance.
Brad Wright of MO
01-16-2006 15:56:13
 Re: WD in reply to Martin Miller, 01-16-2006 15:19:01
Heres a Data sheet.
Manufactured: 1948 - 1953 Total built: 146,125 Factory: West Allis, WI Cost: (US Dollars) $1,830 Power: Drawbar (HP): 19 PTO (HP): 26 Engine: Manufacturer: Allis Chalmers Fuel: tractor fuel Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 4.00x4.00 Displacement (ci): 201 Compression: 4.5:1 Rated RPMs: 1400 Torque (ft-lbs): Firing order: Oil capacity (qts): Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 4.00x4.00 Displacement (ci): 201 Compression: 5.75:1 Rated RPMs: 1400 Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: sliding gear Forward: 4 Reverse: 1 Transmission: Type: constant mesh Forward: 4 Reverse: 1 Capacity: Fuel (Gal): 15 Cooling (Qt): 14 3-Point: Category: snap couple Lift (lbs): Power Take-off (PTO): Type: live Rear speed (RPM): 540 Hydraulics: Type: open Capacity (gal): 5 Total Flow (gpm): Outlet Flow (gpm): Outlets: Tires: Ag front: 5.50-16 Ag rear: 11-28 Dimensions: Weight (pounds): 3,500 Wheelbase (inches): 88 Length (inches): 127 Width (inches): Height (inches): 81.5 Ground clearance (inches): Electrical: Battery volts: 6 Ground: Battery cold-cranking amps: Alternator amps: Nebraska Test: Test Number: 399 Test Date: July 1948 Engine: tractor fuel Belt HP: 26.1 Drawbar HP: 23.3 Max pull (pounds): 2,536 Nebraska Test: Test Number: 440 Test Date: May 1950 Engine: gasoline PTO HP: 34.6 Drawbar HP: 30.2 Max pull (pounds): 2,369 Serial Numbers: Location: Transmission 1948 7 1949 9250 1950 35445 1951 72328 1952 105182 1953 131243
old
01-16-2006 15:21:57
HP is around 34 give or take a few.
