WD-45 Chrome Straight Pipe
orange-mud
01-12-2006 18:54:09
I bought a chrome straight exhaust pipe for my wd-45 just for the heck of it. I am wondering how i can secure it to the manifold. Muffler that came with tractor just fits inside the manifold and is not secured in any way. The new chrome pipe is heavier and i am worried about too much weight sitting in the manifold. Original parts manual shows a bracket securing the muffler to the manifold. Any one out there have some ideas for me to secure the new exhaust pipe?? Pipe dimentions are 1 3/4" at manifold end///Chrome part is 3 1/2" //total length is about 22 inches. Am i better off just shipping it back to where i bought it?? Thanks--Ray
Steve in N.J.
01-13-2006 14:38:01
 Re: WD-45 Chrome Straight Pipe in reply to orange-mud, 01-12-2006 18:54:09
I had a 2" chrome pipe on my B for a while, and what I did was fit a piece of straight pipe (I think it was 1.5") into the exhaust manifold so it was nice and snug. Then I slipped the 2" chrome pipe over the top of the pipe in the manifold. I cut the chrome pipe like my muffer was (drapeing over the manifold on one side) and attached the chrome pipe with the bolt that normally went through the muffler. The chrome pipe extended a few inches higher to hide the inner pipe. This way, the chrome pipe didn't turn blue from the heat. The pipe fit tight to the outside of the manifold, and the bolt held it in place quite well. She did bark when she was workin' hard, but about a year ago I put the muffler back on. I guess I'm gittin' older and rather have it quieter. It was pretty neat while it was on though....
Steve@B&B
big jt
01-12-2006 21:21:09
WHAT, WHAT DID YOU SAY!!! I'm yelling cause I've gone deaf from running tractors with straight pipes! Partially kidding.
The original muffler for a WD and WD45's was secured to the manifold by two bolts threaded in just below the outlet. You should be able to see where this was usually the bolts break off and get left that way and someone just sticks the new muffler in. If you want drill and tap these holes and make a bracket. Just need a piece of strap with the needed holes and dogleg bend.
Good luck, Have fun, and Get a audioligist on retainer ;
Chris(WA)
01-12-2006 20:54:10
I made an adapter for the straight pipe on my WF by taking an exhaust pipe adapter that fits in the manifold and adapts to the inside of my straight pipe. Welded them together.(my pipe is stainless not chrome but I think the adapter idea will work for you) Then I made a strap that bolts to the attaching bolt on the manifold and welded it to the straight pipe to keep it from flopping. Also put a collar around it to keep rain water from following the pipe down and running into the manifold. You will like your straight pipe. They talk real nice!
tim coltman
01-12-2006 19:02:05
i dont think that extra weight would be a problem unless it wiggled around. you could always fashion a bracket to attach it to the hood to help stabilze it if your worried about it. tim
