WD45 oil bath, air filter level?
joel heaton
01-12-2006 11:04:09
can someone tell me how high to fill the oil in a WD45 oil bath/air filter level?
J Beightel
02-01-2006 08:26:43
 Re: WD45 oil bath, air filter level? in reply to joel heaton, 01-12-2006 11:04:09
Set the oil cup on a level surface and fill till the oil is level with the center pin.
ricedaddy
01-12-2006 16:08:03
per the service manual, it holds 1 pint even!
old
01-12-2006 11:30:27
If you don't see the line that D17 talks about you can also go by the center piece it should have hole in it about and inch or so up from the bottom. You fill till the oil is about the center of the holes, maybe a little bit higher. I would have to go out and look to be right on the dot.
D17JIM
01-12-2006 11:11:02
There should be an oil level line on the inside of the cup that you are filling. About 3/4 to 7/8 of a quart should do it.
Punchie
01-13-2006 04:54:08
 Re: WD45 oil bath, air filter level? in reply to D17JIM, 01-12-2006 11:11:02
Yes I was thinking around 1 qt. or less.
