Castellated rod nuts, WD 45
W. Keitel
01-10-2006 11:30:13
It's been hard to find new castellated nuts for my connecting rods. Thinking about using the old one's. If so 70'lbs torque on castellated and if I use reagular nuts 40'lbs? Which is better. Working on WD 45
The Old Farmer
01-12-2006 19:39:07
 Re: Castellated rod nuts, WD 45 in reply to W. Keitel, 01-10-2006 11:30:13
If I remember correctly, the Castelled nut torque was lower than 70ft pounds, believe 35. Did not find my WD and WD45 manuals tonight.
I am a master mechanic on the WD and WD45 and the ACHD6. Son pointed me to this site. I would be glad to help on questions when I have the time.
Next time I will not post without a manual in hand.
I bought the first WD in Northern California, serial# 165, July of 1948 with money saved during WW2. $1850. (Tank Commander/Squad Leader at age 18)
Overhauled the WD engine in 1995 (47 years later).
Used +1/8" sleeves and switched to the 1/2" longer stroke WD45 crankshaft. If I remember correctly, went from 206 cu in to 226 cu in.
Doug Boll
01-10-2006 13:01:29
On the old Cases I use the old castle nuts over and run a chaser over the bolts. The keys are overkill but I put them back in anyway
Zonie
01-10-2006 12:19:21
The castelated nuts were used with saftey wire to keep the nuts from coming loose. the regular nuts were a crush nut (lock nut), if your rod bolts are drilled for the saftey wire then I'd use them.
