Starter/Starting Problems
Earl Dixon
01-10-2006 08:46:24
I have a 1994 D-10 model. We have always had problems cranking this tractor. I am converting it to a 12 volt system. Will this conversion provide easy starting? Need your input. Earl
John T
01-10-2006 09:15:55
 Re: Starter/Starting Problems in reply to Earl Dixon, 01-10-2006 08:46:24
Earl if you apply 12 volts to an original 6 volt starter, and provided it and all else is okay, fer sure she will crank over pretty rapid. It can be a lil tough on starter drives but Ive had good luck on the ones I converted (not any AC however). Of course, dont forget the other conversion requirements such as to the charging system and lights and possibly ground and coil and/or ballast resistors if its a battery powered coil ignition. Before conversion, you may wanna consider the use of a good heavy duty high CCA or Amp Hr battery (biggest that will fit in compartment or even an AGM battery) plus the use of 0 or even 00 Gauge Battery n Starter n Ground cables and/or attaching the ground cable nearer to or on the starter mount, all of which can improve cranking speed. Are you sure the starter motor and switch or solenoid and battery are all strong and okay?? Any of those may be weak causing slow cranking also.
Let us know, best wishes n God Bless
John T
Earl Dixon
01-10-2006 09:02:18
Correction: A 1954 D-10! Earl
