D19 Injector Pump
Bertsie
01-10-2006 08:10:11
The last 2 times that I started my D19 diesel up I found that I have no throttle control. When I put any load to it the rpm's drop too too low for the oil pressure. I have changed fuel filters and also ran SeaFoam through the system. I am assuming that the governor is not reacting and there may be something else amiss. Thanks.
jdemaris
01-11-2006 07:26:43
 Re: D19 Injector Pump in reply to Bertsie, 01-10-2006 08:10:11
Assuming you've checked for external fuel problems, then like the other guy stated, if you have a Roosamaster DB injection pump, it's probably the plastic weight-retainer ring falling apart. If you have somebody around that knows these pumps, it's an hour job to take one apart and fix it - plus around $40 in parts. If you want to know for sure - take the return fuel fitting out of the top cover of the pump. I don't mean just unhooking the line, take the entire fitting out. Fuel will then run onto the ground so don't run it long. If it runs good with the fitting out -then the ring is broken. You can also check by taking the the little timing-inspection window off the side of the pump. Once off, if you see little black specs that look like mouse turds -then the ring is broken.
Strange Brew
01-10-2006 21:34:49
could be the gov. weight carrier retainer flaking apart, lil pieces can plug off return line, most time they wont run, but I had one that acted about like yours. Could also be the transfer pump?
