WC starter
esbenshade
01-09-2006 15:30:37
Hey i have a starter that is beileved to be a WD starter. I had the starter rebuilt but does not hook up to my starter system on my WC if anyone has a WC starter and would like to trade e-mail me.i would like the starter to be rebuilt. you can also call 786-0176
Tim Tenn.
01-11-2006 06:38:22
 Re: WC starter in reply to esbenshade , 01-09-2006 15:30:37
The WD starter will work. The difference is the solinoid is on the oppisite side. I took off the foot rod and changed it to the pull rod from the WD. You can make a rod if you don't have one.
Texas Denny
01-10-2006 08:24:39
I don't understand the phase "but does not hook up to my starter system on my WC". Does this mean it doesn't hook up electrically? Or does it mean that it doesn't fit? Or does it mean the starter rod doesn't connect. I'm not sure if the levers for the switch on the WC and WD are the same. On my WC, the lever is pushed forward. On my WD, you pull toward the steering wheel. I think that the same starter switch works on either - just take the switch off and rotate. The hole for pushing is bigger than hole for pulling and the starter is rotated about 180 degrees.
old
01-09-2006 16:18:30
What type of problem are you haveing. I have a WC speed patrol and it has a WD starter on it. The engine and tranny of the WC speed patrol is the same as a WC tractor.
esbenshadee
01-10-2006 13:00:48
 Re: WC starter in reply to old, 01-09-2006 16:18:30
the starter on mine does fit but we cant get it to hook up right. other words we cant get the switch to make contact to the post on the starter.
gene (missouri)
01-12-2006 06:40:11
 Re: WC starter in reply to esbenshadee, 01-10-2006 13:00:48
If I read this right.
Pull the cover off the starter switch. Under the cover should be an adjustable post (bolt)with locking nut that is one of the electrical contacts. Loosen the locking nut and back the bolt out one or two full turns.
Gene
old
01-10-2006 13:06:13
You probably have the same problem I'm haveing with my WC speed patrol. The switch is just plain going bad. My guess is that if you buy a new switch the problem will go away. I have to install a new switch my self I have it just haven't gotten around to putting it on.
