WILL F GLEANER DIESEL MOTER FIT IN WD 45
chester dubois
01-08-2006 21:09:54
Will a Gleaner F Diesel moter fit down in a WD or WD 45 if so need to know how to make it fit and to how to bolt it up to the bell howsing making it to pull im get er done one way or the other AC fans HELP me out !!!!
matt jamison
01-10-2006 19:05:36
 Re: WILL F GLEANER DIESEL MOTER FIT IN WD 45 in reply to chester dubois, 01-08-2006 21:09:54
i have a wd45 with a 262 diesel out of a D-19 in mine, had to make some changes, like oil filter has to be relocated, injector pump hit the frame rail, had to do a little cutting there and you need to copy a adaptor plate off of a wd45 diesel to bolt it to your tractor, it takes some work to get it in a former gas tractor, the grill has to be moved forward all the way the front, I run no belts on my engine. no charging,electric fan, electric water pump all off of the battery, it makes a heck of a puller. its a real head turner when that little allis has a big 6cyl. diesel blowing black smoke. I've had very very good results with mine
Gary57050
01-09-2006 04:14:59
To make a long story short you really need to start with a WD45 Diesel to put the 262 in a WD45
unless you want to run down a bunch of parts
