If your tractor has the three position switch, it came from the factory as a 6 volt system. It did not have a voltage regulator. So yours has been coverted to a 12 volt system by adding a 12 volt regulator and a 12 volt generator (I assume generator since you didn't mention an alternator). You essentially will not use the switch for anything but the lights. If you look closely at the terminals on the 4 position regulator, you should find letters stamped on the terminals. They should be labeled A (armiture), F (field), B (battery). The 4th terminal will either have L (lights) or G (ground). In most cases, a three terminal regulator can replace a 4 position. It isn't easy to determine if the regulator you have is compatible with your generator. How did you determine which regulator to buy? Hook up the regulator as the terminals suggest - B to Battery, A to Armiture but leave the field terminal disconnected. I'm not an expert but I have made a few of these work. First off, there are two types of generators. On one type, if you jump 12 volts to the field, the generator will charge at maximum. On another type, it is necessary to ground the field terminal to get it to charge at maximum. You need to do each of these to determine which type generator that you have. Then, with the tractor running, check the voltage on the field terminal of the regulator. If there is no voltage, the regulator is designed to work with the generator that charges max when the field terminal is grounded. If the regualtor has battery voltage on the field terminal, it is designed to work with a generator that charges max when battery voltage is applied to the field terminal. Once you have generator and regulator that match, the system should work fine without the hi/lo charge switch.
