Allice Chalmers B
Chad from MD
01-06-2006 17:45:16
I have a AC B. I would like to know what the bore, stroke, horsepower, Cubic Inches and torque is. I would be very grateful.
Thanks a lot
steve(ill)
01-06-2006 18:46:23
 Re: Allice Chalmers B in reply to Chad from MD, 01-06-2006 17:45:16
look at the engine number on the back left corner boss by the flywheel. If it is a BExxx motor it started out as a 3-1/4 inch bore. If it is a CE motor it started out as a 3-3/8 inch bore. THey are the same block and may be updated from original. The horsepower is about 22 and the tractor weight is about 2200 pounds. Allis tractors are known in general to be a high HP to weight ratio. Most will easily slip the tires befoe you kill the motor.
