original tire size wd 45
tim coltman
01-05-2006 12:00:12
hi would like to know what the original front tire size was for WD-45 and the pattern like if it was ribbed or not ive got oddball truck tires right now id like to get rid of. thanks tim
JoelS
01-06-2006 09:56:11
 Re: original tire size wd 45 in reply to tim coltman, 01-05-2006 12:00:12
Nebraska test book shows 14.9 x 28 rear open tread. 5.50 x 16 3 rib front.
ricedaddy
01-05-2006 15:45:29
JOHN (MO) is right with 28lbs air pressure, this is coming from the service manual
Cadet trooper
01-05-2006 15:39:00
Yep, John from Mo is right according to the Red Book 5.50-16 (I'm guessing triple rib) w/12-28 rears. I assume you know it has a lot to do with what size rear tire is on your tractor now so it isn't going up or down hill all the time. We did that once went up one tire width on the rear of an H Farmall and it looked like we had a set of balloons on the rear. My suggestion is check with a local farm tractor tire shop or the web and they can match your tires very well. Good luck.
John (MO)
01-05-2006 12:09:04
I think they were 5.50-16's in a 3 rib design.
