WD 45 Leaking oil
Randy Freshour
01-04-2006 16:08:00
Its leaking around the shaft that connects by linkage to the hand clutch. It goes into the transmission housing. Is there a seal I can replace around this shaft? If so can it be done with out splitting the tractor? My repair manual is pretty vague.
wdtom
01-04-2006 18:10:29
 Re: WD 45 Leaking oil in reply to Randy Freshour, 01-04-2006 16:08:00
You will have to take the cover off the top of the clutch housing,under the battery and remove the shaft, the lever is welded to the end of it. To do this you will have to remove the frame rail. then the seal is an easy job. The right frame rais isn't as easy to remove as the left, but it has to come off. Just support the tractor. The capscrew that holds the radiator on can't be long or it will punch a hole in the bottom tank of the radiator, remember this when you put it back together. Everything else is fairly simple see it and do it. Don't forget the steering shaft support inside the frame rail beside the engine. The shaft is held to the clutch release fork by a tapered point screw like what is in the brakes, starter hold in screw, and belt pully hold in screw. The seal is Allice Chalmers no.224624
