rear rims
jbanet
01-04-2006 07:51:00
I have a 47 wc. Is there any way to put 8 bolt wd rims on it? I have a couple of set I want to use on it.This will be a puller.So any way to change it will be help full thanks.
thanks j banet
01-05-2006 06:48:57
 Re: rear rims in reply to jbanet, 01-04-2006 07:51:00
I dont have true wd rims just wanted 8 bolt pattern. They are combine tires and rims. thanks
big jt
01-04-2006 12:50:19
Will be difficult. Different bolt pattern. Course you already know that.
You won't gain much on weight. You would be better putting on a pair of fixed dish pressed steel rims.
If the WD rims are spinouts in good shape You should be able to find someone to trade with.
I think I could come up with a pair of round spokes off a F20 that I would trade for a pair of GOOD WD 45 rims. I think the F20's will fit but I'm not sure.
just my 2 cents worth your milage may vary.
jt
Texas Denny
01-04-2006 11:44:41
I don't know if they fit directly. Someone else may. If you have access to a mill and a laythe, you can make an adaptor plate out of 1" steel plate. You must have good equipment for this so the center fit properly - they are more important than the lugs.
