Model 7010
Dixieland
01-03-2006 18:19:38
Would anyone give me some advice on a model 7010 tractor? I need to know the pros and cons of this model and the performace I can expect. Also, what is the HP. At this time all I know is it is a diesel! Any help would be appreciated.
Thanks in advance,
Rex
Brad Wright of MO
01-13-2006 15:51:05
 Re: Model 7010 in reply to Dixieland, 01-03-2006 18:19:38
Here ya go
Manufactured: 1980 - 1981 Cost: (US Dollars) $35,311 Power: Drawbar (HP): 91.0 PTO (HP): 107.52 Engine: Manufacturer: Allis Chalmers Fuel: diesel - turbo Cylinders: 6 Displacement (ci): 301 Compression: Rated RPMs: Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: SG Forward: 16 Reverse: 4 Transmission: Type: PS Forward: 20 Reverse: 12 Capacity: Fuel (Gal): 3-Point: Category: II,III Lift (lbs): Power Take-off (PTO): Type: independant Rear speed (RPM): 540 1000 Hydraulics: Type: open Capacity (gal): Total Flow (gpm): Outlet Flow (gpm): Outlets: Tires: Ag front: 10.00-16 Ag rear: 118.4-38 Dimensions: Weight (pounds): 11,224 Wheelbase (inches): Length (inches): Width (inches): Height (inches): Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps: Serial Numbers: Location: Above PTO shield 1980 1925 1981 2806
dnkkt
01-08-2006 04:29:52
I have a 7010 and bought it new. this has been a good tractor.I will say that the only thing i had a problem with was that this tractor didnt come with a water filter on it. we bought it new and it came that way. It either need a filter or extra coolant in the water. with not having the filter the water bored little hole in the cylinder and had to have it rebuilt.never had a problem with it sence, been 10 years.Also the radiator fins can pug up with dirt, ned to say on top of it.This is a very good and srong tractor.
cadet trooper
01-05-2006 15:59:27
It's a 7020 without an intercooler and that's it.Very solid tractor, probably the most solid of the 7000 series line because it is running on the low end of the 301ci load but still has kick and a little room for an attitude adjustment with a strong drive train. I've put a lot of hours in one. I can tell you of one thing to be aware of is radiator core air flow openings we had a lot of problems with dirt building up in the those cells and had to stop and power wash them out. In summary radiator needed more air flow otherwise one of the best 100hp tractors made. Good luck
Joe(TX)
01-04-2006 14:05:33
A good solid tractor. 106 hp and weighs around 11000 lb without weights. Can have a 12 speed power shift ar a 16 or 20 speed power director transmission. Independent 2 speed pto. The only negative is finding a parts dealer (AGCO) close by.
I just bought one myself.
