AC G timing marks and 4 speed transmission adn hyd
Greg Lasher
01-02-2006 15:54:22
Hello - I have three questions.
First now that I reinstalled the distributor on my G and I have it running were do I locate the timing marks to get the final timing done. On YT mag it says there is a mark on the flywheel is there a bolt you have to take out or a cover you look through?
Second - it appears this tractor has 4 speeds but none seems extra slow -- wasn't the 4th sleed a creeper gear. I don't see i marked on the tranmssion housing I only see 1,2, and 3. Maybe I put it in 1st gear twice and it is only a 3 speed I did not run ti that long. How do you tell?
Third what type of hdraulic oil does it take and were does it go -- I don't see a resivor -- is is sumped with the transmission??
Thanks
Greg
Dick L
01-02-2006 17:46:17
 Re: AC G timing marks and 4 speed transmission adn in reply to Greg Lasher, 01-02-2006 15:54:22
On the timing peek thru the little hole in the bottom center of the back cover. Just below the crank hole. Between the two bottom bolts. It is timed to the notch in the crankshaft pully seen thru this hole.
third party image
The slow slow gear is located far to the right of the gear numbers that are on the transmission case and then forward.
Dick L
01-02-2006 18:15:32
 Re: AC G timing marks and 4 speed transmission adn in reply to Dick L, 01-02-2006 17:46:17
And the oil for the transmission and the hydraulic system is the same oil. SAE 20 is what the book will probly call for but most tractor hydraulic oil will do fine.
