need HELP TIMING 1940 c
JB toys
01-01-2006 17:51:09
I went to change the cap and rotor button now my timing is out the s# C 19265 i have found the fire mark and the center mark i have own this tractor for 1 year a golf ball flew out from under the lawn mower and hit the cap this is the first thing to go wrong not the tractors fault
Rod (NH)
01-01-2006 18:37:33
 Re: need HELP TIMING 1940 c in reply to JB toys, 01-01-2006 17:51:09
Hi,
I assume you replaced the large main cap and not just the small cap that covers the rotor. I also assume it's an FMJ mag. If you didn't remove the mag itself, you'll have to reinstall the main cap (cover) so the internal gears mesh in the proper position. If you removed the mag from the tractor, you'll also have to time it to the tractor as well as reinstalling the cap properly. You can find instructions for doing both in the first two links on my web page here. The instructions are for a B but a C should be indentical. You'll note that there are two different ways to time the mag to the engine. One uses the center mark and the other uses the fire mark. In other words, you can use either flywheel mark but must use the correct procedure that goes with it.
third party image Rod
jbtoys
01-02-2006 05:49:28
 Re: need HELP TIMING 1940 c in reply to Rod (NH), 01-01-2006 18:37:33
it is a 1944 c my marks are a little differnt on the mag olny one tooth mark. When i try to put it to the top it fire and is off of center thanks for all your help
