wd45 lift arms stuck
foxtrotter
01-01-2006 16:27:21
The lift arms on my WD 45 are stuck in the "up" position. Any suggestions?
JackT
01-03-2006 19:09:14
 Re: wd45 lift arms stuck in reply to foxtrotter, 01-01-2006 16:27:21
If its still plumbed up in the original way only one cylinder does the "hold position" work. Most likely there is a problem in the linkage and the hold position check valve ball isn't getting lifted off its seat. Get a copy of the manual and read up on the "hold position" valve assembly. Easy way to check is to remove the forward-most hyd line from the hold position valve. I'll bet it'll squirt oil all over the place and your implement will drop like a ton of bricks. If so, the problem is in the valve.
JMS/MN
01-01-2006 20:55:46
Lift arms do not normally come down due to their own weight. When you say they are stuck, is there a mounted implement on them? Then they should come down with the lift lever lowered.
foxtrotter
01-01-2006 21:31:06
 Re: wd45 lift arms stuck in reply to JMS/MN, 01-01-2006 20:55:46
yes there is a blade attached. Additionally, when I stand on the blade and try to weight it down a bit to get it to lower, it will not.
old
01-01-2006 16:32:24
Check the valve to see if its wroking right and also the cylinder either one can/will cause the problem
foxtrotter
01-01-2006 20:29:47
 Re: wd45 lift arms stuck in reply to old, 01-01-2006 16:32:24
Thanks, Where is the valve that I check, and how do I do it? Also, how do I determine if the cylinder is bad?
JMS/MN
01-01-2006 20:59:14
 Re: wd45 lift arms stuck in reply to foxtrotter, 01-01-2006 20:29:47
Very unlikely to be a cylinder problem. The OPERATOR manual shows details on adjusting the several controls on the hydraulic system. Buy that first to learn the controls, adjustments, lube, etc. of a really good tractor.
