200 Allis
Chris R.
12-31-2005 08:48:29
Bought a 200 last summer, used it for making hay, worked great and easy on fuel.In fact I put more hours on it than my 4020 John Deere.Was told they have a heck of a good engine but the transmission and rear end won't hold up for heavy work.How true is that? I know the 190's had some problems, but I thought all that was corrected on the 200's and the 7000 series. What kind of luck have you guys that actually have 200's had with them? Thanks
Brad Wright of MO
01-13-2006 17:01:55
 Re: 200 Allis in reply to Chris R., 12-31-2005 08:48:29
I have owned an allis 200 and have used it for many things. The only major problem I have ever had is with it heating up a little to much. We just have to keep the grill real clean and everything. I have used the 200 for things like: light tillage, moving hay, mowing hay, baling hay, pull things out of the mud, planting, spraying you can do a lot with these tractors.Also you mentioned road speed. Mine goes about 16 mph. Also heres a data sheet about them.
Manufactured: 1972 - 1975 Cost: (US Dollars) $14,125 Power: PTO (HP): 106 Engine: Manufacturer: Allis Chalmers Fuel: diesel - turbo Cylinders: 6 Displacement (ci): 301 Compression: Rated RPMs: Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Forward: 8 Reverse: 2 Capacity: Fuel (Gal): 3-Point: Category: II Lift (lbs): Power Take-off (PTO): Type: Rear speed (RPM): 540 Hydraulics: Type: open Capacity (gal): Total Flow (gpm): Outlet Flow (gpm): 17.2 Outlets: 2 Tires: Ag front: 7.50-16 Ag rear: 16.9-34 Dimensions: Weight (pounds): 7324 Wheelbase (inches): Length (inches): Width (inches): Height (inches): Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps: Serial Numbers: Location: Torque housing 1972 1001 1973 3344 1974 6294 1975 9250 Links:
Farmered
01-02-2006 01:11:13
Allis Chalmers had a recall on the 190XT back in the early 70s when I was a dealer. It was an internal thing and not advertised. Only units that had caused trouble were affected. The original two spider differential was replaced with a three spider unit. A company engineer came out to set up the gears. My customer had been pulling 6 bottoms with his XT when he tore up the gears. The engineer, when he noted the stone cuts on the tire tread bars said lets put her on the dino. It was putting out 120 HP. He turned the fuel screw back to about 97 HP which is what he said they were set for when they left the factory.(rated 94 HP) I assume that the 200 had the 3 spider rear end. Ed
Chris R,
12-31-2005 18:17:18
Sounds like you guys know something about 200"s. Road gear is a little slow, seems like it should have one more gear. Here"s a little history on my 200. I bought it from a lady about 5 miles away, her husband had passed away,and she wanted to get rid of it. They were retired and the tractor had not been used much for the past 5 or 6 years. It has 2150 hours on it, the engine was rebuilt about 1000 hours ago, had a cracked sleeve antifreeze was getting in the oil and smoked white. They put all new sleeves and pistons and rod and main bearings in it trued up the head and block.I know the mechanic that did the work and have the bill with all the parts and labor on it,so I know everything she said about it was true.Sounds too good to be true,but it is. Other than a few little dings on the hood it looks and runs like a new tractor. The only thing i"m not happy about is it is hard to start in cold weather unless I plug it in. Haven"t checked the pump timing yet, maybe thats not quite right.If it is plugged in it starts fast. Chris
Hurst
12-31-2005 11:53:47
I am not sure what specific problems they are talking about when referring to the rear end. There are quite a few that could happen that I know of. The biggest thing is probably the differential. The early 190xts had the D19 rear end and a lot of them came out of the factory with a pump that was putting out a lot over what they should have been adn then people turned them up and eventually the diff just went byebye. That was fixed very well by the series 3 190 xt and the same differential, brakes, and final drives were used on the 200 and 7000 also. The other big problem I know of is the thrid gear or sometimes 2nd and/or 4th. This was not a manufacturing problem, instead it was an operator's mistake that caused this. A lot of people wouldn't wait the 3 or 4 seconds it would take for the transmission to stop spinning when they put in the clutch and therefore grinded the gears, eventually causing the collars and gears to get worn on the edges where they would pop out. This was a problem on all of the hundred series (170 to 200 mostly, but some 210s and 220s, but not many) because of the length of the gear shift was longer than what was used on the d series, which meant the gears would wear a lot faster when grinded. Also, shifting gears on the fly (power director is ok to shift on the fly) would cause this over time. The other problems that I know of are not very common. These are transferring fluids between the differential and the transmission/hydraulics, which was caused by a seal in the powerdirector going out most of the time and forcing fluid through the input shaft seal or just the input shaft seal going out, and even sometimes, the problem was the pto shaft seal. The other problem is the power director jumping out or just not working from being worn out and just needing either rebuild or adjusting. All of these problems could be avoided and never have happed if users were just more careful about maintenance, driving the tractor like a car (tractors don't have syncos in the tranny) or just turning up the pump. Also, I forgot to mention that the 7000 had a tranny brake added so that it was next to impossible to shift on the fly and kept you from grinding gears when stopped. Another problem that is almost nonexistant that I am having with my 7000 is the transfer of fluid between the differential and the final drives, most likely from a lack of changing fluid, therefore the seals wore out prematurly or else the bearing cabs are not sealing correctly. Good luck. The 200 is a good, simple, and easy to work on tractor. One thing to watch out for is a crack in the oil pan at the front where it starts to make a sump for the oil pump and oil leaking around the front timing plate. These are signs of a loose timing/adaptor plate and it is not fun repair, and really a lot less fun on a 200 than my 7000 because the 200 requires the front end to be pulled where I could just squeeze everything in on the 7000. This being really loose can cause the injector pump to seize up if you ever bottom out one side of the axle in a valley or something because of the twisting of the plate and the side load on the injection pump, which it can hardly handle any side load at all. Good luck and post back if you have any more questions.
Hurst
mnjoe
12-31-2005 09:57:02
I have been using my 200 for about 3 years now. No problems so far. The first day I used it to disk it took about 2 quarts of oil....Thought what did I buy. I was working it HARD. After that never used a drop. My only complaint is road travel....wish it was faster.
JONES FLECHER
12-31-2005 13:24:59
 Re: 200 Allis in reply to mnjoe, 12-31-2005 09:57:02
HELLO AND HAPPY NEW YEAR TO YOU.I SAW YOUR ADVERT AND AM VERY MUCH INTERESTED IN BUYING IT PLEASE GET BACK TO ME IF IT IS STILL AVAILABLE.
THANKS JONES FLECHER.
