WD45 tranny
s.d. persall
12-30-2005 09:32:54
My WD45 seems to be stuck in fist gear, but the shifter seems to be it the neutral position. I tried to remove the shifter cover (the housing that the shifter comes out of) but I am unable to get the fork for reverse to disengage from the gear. It wouldn't come out. HELP!!! I use this tractor to plow snow off my driveway and need to repair it ASAP!!!!
SEK
01-02-2006 12:23:32
 Re: WD45 tranny in reply to s.d. persall, 12-30-2005 09:32:54
I have had a similar problem with my WD45. Mine gets stuck in 2nd gear. I decided to drive it back to work on it, and when I was on my way back it suddenly slipped into neutral. It�s happened several more time. Each time, as I drive it just pops back into neutral. Have you tryed driving it to see if it pops back into nuetral?
Fredd
12-31-2005 06:30:07
This is a common problem of the WD45s and straight WDs. The bottom of the shifter lever gets wore and will slide between the top of the forks and leave the machine stuck in gear. There are two ways to fix this. On the top of the shifter column, where the shifter goes into the cast piece, there are a couple snap rings and a spacer or two. take these out and you can pick the shifter lever right up out. Now you can see the top of the forks and get them in line; the tractor out of gear. Once this is accomplished you just put the shifter lever back in. The other way is to take the whole top of the transmition off as you seem to be trying to. I'm not sure about the stuck reverse fork, as I have never had a problem getting the top of the transmition off. Once you have it off and the gears back in neutral, it is a son of a b#%$* to get the top of the transmission back on. I have thought about trying to add on to the bottom of the shift lever in an effort to stop it from slipping out but have not completed the project. After it slips out enough and you tear the snap rings and shifter lever out the the transmission a couple times, you learn what is going on in there and how to get it slipped back in without tearing anything apart, like I do. It is somewhat odd that it slipped out of first for the most common gears to go are reverse, 4, and 3. Hope this helps.
