removing steering wheel - AC Model C
todinbenson
12-30-2005 04:08:00
How do I remove steering wheel from my Allis Chalmers C?
Steve Jelf, So KS
01-01-2006 08:37:31
 Re: removing steering wheel - AC Model C in reply to todinbenson, 12-30-2005 04:08:00
Rather than banging on the steering wheel with a hammer, I'd put a block of wood against it and pound on that. Less likely to damage the wheel.
RandyN
12-30-2005 15:51:32
Remove the acorn nut from the end of the shaft. Essentially, the steering wheel should pull off of the shaft, however, if it's been on there for many years, it may take a little encouragement from a hammer. Tap on the backside of the wheel, on the spokes near the hub, alternating spokes until it finally breaks free. Squirting in a little PB Blaster or WD-40 might help also. Once removed, you should see that it's a plain shaft with a key in a slot. Watch that the key doesn't fall and "disappear".
Some people speak of heating it, then tapping it, but I've never had to heat up a steering wheel to remove it.
Good luck,
RandyN
todinbenson
12-31-2005 03:20:51
 Re: removing steering wheel - AC Model C in reply to RandyN, 12-30-2005 15:51:32
Thanks. That is what I have been doing, just making sure thats how to do it. Do have another question. If I am restoring this tractor, should I put the magneto on or leave it with the distributor - it had been converted. Also, will the magneto cause any problems?
