WD45 rim size
JackT
12-29-2005 10:21:05
How do you measure the size of a WD45 rim? Standard is supposed to be 12 x 28. The tires on mine read 13.6x28 on 12" rim, but when I measure the width of the rim it measures 10" wide. Can I fit bigger tires such as 16.9 x 28 on the original rims?
Thanks
JMS/MN
12-30-2005 08:11:27
 Re: WD45 rim size in reply to JackT, 12-29-2005 10:21:05
You can generally go an inch wider or narrower than actual rim width. The rim is measured where the bead is seated. A 12 inch rim can take a 13 inch tire, which would be a 14.9 tire (current marking system). A 16.9 tire is common on a D17, but you need a 14 inch rim. That would affect ground speed quite a bit on a WD45, although the rim and tire would bolt on.
old
12-29-2005 11:24:20
You could do so but, the tire wear would be a lot differant and probably also give you other problems. You might be able to go with 14.9X28 but I think that would also be pushing it some.
