Gemmer shaft seal on C
RandyN
12-27-2005 15:47:03
Hi,
Would anyone happen to know a seal-cross reference number for the oil seal on the cross-shaft of a Gemmer steering gear on a C?
The Allis part number is 212065.
Thanks ahead for any posts.
RandyN
Jerry Coulter
12-28-2005 08:44:18
 Re: Gemmer shaft seal on C in reply to RandyN, 12-27-2005 15:47:03
When I replaced a bearing in my C's Gemmer box, I cleaned out all the cork residue and installed a National Seal having the same outside dimension for the 1.125" shaft. I am not able to locate the seal number just now. And I filled it with straight STP for lubricant to protect the bearings and worm from any further wear. I don't particularly recommend STP because the stuff tends to ooze out. Messy!
wdtom
12-27-2005 18:21:47
If you have much trouble with seals or other things involving lube, just put a grease fitting in the side of the box and grease it a few strokes every time you grease the tractor. When you put it together fill it with grease. A box full of grease will lube it fine even with no seals.
