WD, How Many Plow?
RBL
12-27-2005 07:19:43
Hey guys,
I know the WC is rated a two plow tractor, is the WD, two or three plow? Thanks.
BushogPapa
12-28-2005 06:29:43
 Re: WD, How Many Plow? in reply to RBL, 12-27-2005 07:19:43
Here in Ohio, I never had "Clay ground" pull very hard..BUT..we have "Yellow Wax", and "Black Wax"..(Black Jack)...!!! The Yellow Wax sticks and either is hard like concrete, or chewing gum..unless you catch it in the "right mood", and it turns good.. The Black wax can turn easy as ashes, OR Hard enough to break parts...it is a lot in How and When you plow, as to how much you can pull through it...!! When a WD-45 leaves Rubber, when a tire slips, it is time to wait for a Rain..!! Here, every WD pulled 3-14" and did it well.. The WD-45 could pull a 3-14 in 3rd gear, but used more fuel per acre than 4-14" in 2nd..(semi-mounted)... Ron..
Texas Denny
12-27-2005 19:30:50
I think you asked what was it rated? Allis Chalmers rated it 2-3 plow.
Leroy
12-27-2005 19:01:21
Friend of mine that knows AC says the first WD used the same engine as the late WC, Later WD had a more powerfull engine and still later WD45 was still more powerfull, Uncle Had bought a new WD with 3 bottom plow (Don't know size of bottoms) after a couple of years 3rd bottom came off that plow, A neighbor years ago had a WD & 3-12" AC plow outfit worked good burn up in barn fire, bought anouther WD but with 3-14" AC plows and could hardly move it. Anouther neighbor had a WD45 pulling 2-14" AC plows next to a Farmall H pulling 2-14" plows and said that WD45 could not handle anymore. The Uncle that had that WD got sick one year and neighbors came together to get his crops in the ground, one of his church members brought his WD45 with the 4 bottom plows he used at his home, 10 mile away, and could not move them in my uncles ground
CHALMERSBOB
12-27-2005 18:16:28
I DON'T PLOW WITH A WD, BUT I PULL 2-14S BEHIND MY CA, WHICH IS 1/3 LESS TRACTOR THAN A WD.
EVERYBODY IN OUR NEIGHBORHOOD SAID TO PULL 1 PLOW LESS THAN THE TRACTOR IS RATED FOR IN OUR SOIL. BUT THE CA DOES FINE. BOB
Bill(Wis)
12-27-2005 17:20:00
I have varying soil conditions on my farm. Our '49 WD pulled a 2-14 Allis mounted plow and we never dreamed of putting any more behind it, but that was because of the red clay knolls and heavy bottom soil. Sandy loam plowed real easy and the WD could have handled a 3-14's there. I guess my advice pretty much falls in line with the rest. I will say this (again), a WD will pull 2-14's anywhere.
Aaron SEIA
12-27-2005 12:43:07
Depends on the soil and if it's got WD45 goodies in the block. Mine pulls 3-14's pretty easy, but it's got a 45 crank, head, and carb. 2-16's would be an easy pull, 3-14's would be a bit rough and 3-16's better be in light soil or shallow plowing.
Aaron SEIA
old
12-27-2005 07:33:30
Sort of depends on the soil. The WC and WD use the same engine but differant trannys/rear ends. I my self wouldn't use any thing but a 2 bottom 16 behind a WD, but I live where theres rocks and clay so it can be hard pulling.
