timing mark on a '39 B
maricopa
12-25-2005 07:28:10
I recently bought a so-called service manual from E-bay and would you believe it doesn't mention any timing marks?? Where is the timing mark to be found? I have the timing procedure (from this forum) but do not know where the mark is.It is a '39 hand crank.
Thank you in advance.
steve(ill)
12-25-2005 19:22:18
 Re: timing mark on a '39 B in reply to maricopa, 12-25-2005 07:28:10
look thru the 1 inch hole. listen for the mag to SNAP when you are at the TDC mark. when running it will advance to the fire mark.
Dick L
12-25-2005 15:38:58
I have found two that did not have timing marks at all. Both were crank starts without the ring gear. I have never found a flywheel that had the ring gear without timing marks. I have seen both a line with (center) stamped below a line and TDC stamped below the line.
jaywdep
12-25-2005 13:23:37
I believe there is 2 marks one is the FIRE mark and one is the CENTER mark I have a CA and that is the way it is , Jay
old
12-25-2005 08:10:37
To add to what Steve said, you may need to spray carb clearer etc in there to see the marks.
Steve Jelf, So KS
12-25-2005 07:53:40
There's a hole, about an inch wide, on the left side of the clutch housing, where you can see the side of the flywheel. The mark is a straight horizontal line with the word FIRE above it.
