B Anchor Plate
Rod (NH)
12-24-2005 17:42:17
Since Mike (just below) brought up the matter of front wishbone weights for the B, I thought I would post a dimensional drawing (pdf format) for the anchor plate that they are attached to. That plate is sometimes lost and not available, even if one is lucky enough to find some wishbone weights for sale. However, the plate is fairly easily constructed from sheet steel. Here's the drawing. The top 7/8" dia hole fits over the axle pivot pin just forward of the axle itself. There are two 3/4" dia "J bolts" that are inserted from the rear through the outer two 3/4" dia holes in the middle area of the plate. The J portion of those bolts wraps around the wishbone axle. Each of the two weights are lifted up and slid over the protruding J bolts, back-to-back, one at a time. Nuts are then installed and the weights clamped to the axle.
third party image Rod
Mike in Ohio
12-26-2005 11:27:48
 Re: B Anchor Plate in reply to Rod (NH), 12-24-2005 17:42:17
Thanks again Rod. Since Santa brought me a new welding helmet I guess I'll have to see what I can do with that drawing. Happy new year. Mike
