AC B engine
Tim Anstine
12-24-2005 17:16:11
I've put new liners,pistons,and rings in a 1940 b.The problem is I have a hard time cranking it by hand or with the battery.If I pull the spark plugs out it cranks easy.Everything is in spec.I can leave the bearings lose and add a second head gasket ,it don't make a difference.The new parts are for a CE engine.I have a BE engine if that makes a difference?
steve(ill)
12-25-2005 19:30:02
 Re: AC B engine in reply to Tim Anstine, 12-24-2005 17:16:11
if it cranks easy with the plugs out, then it is not bearings or internal dragging. some new engines are a little tight after overhaul with new rings. it might help to drag tractor behind the truck to get it to go. after running 30 minutes it should loosen up so starter will work.
