AC HD 7
Jerry Cagle
06-24-1998 21:29:17
Have a HD7 with a problem in the final drive, right side, replaced all bearings & final drive pinion & bull gear, Stripped gears 1st day after. need help jlc
Lee Bradley
06-26-1998 08:17:33
 Re: AC HD 7 in reply to Jerry Cagle, 06-24-1998 21:29:17
: Have a HD7 with a problem in the final drive, right side, replaced all bearings & final drive pinion & bull gear, Stripped gears 1st day after. need help jlc
Why did you replace the parts in the first place? If the gears stripped, you may have a warpped housing. HD-7's have the HP to break a gear if you get them in a real pull. Did a gear break or as you said the gears stripped? If the gears stripped I would guess you got a bad set of gears, not heat treated properly. What kind of lube are you using?
Good Luck and let's keep those 7's running,
Lee Bradley
