Question for Rod NH
Mike in Ohio
12-23-2005 15:45:12
I saw the picture of your B with the haywagon in a post below. How much does that weight on the front axle weigh and do you know where I can get one? I use my B to mow with a 6' 3pt mower. Tractor has plenty of power and the hydraulics pick it up just fine, but as soon as I start forward the front end comes up.(sorta defeats the purpose of picking the mower up). Thanks alot, and Merry Christmas. Mike
Mike in Ohio
12-24-2005 10:08:38
 Re: Question for Rod NH in reply to Mike in Ohio, 12-23-2005 15:45:12
Thanks alot for the responses.I've been trying to figure a way to do something like BCnT said but mounting to the wishbone axle doesn't seem as easy,but I got all winter to figure it out.As far as originality is concerned I'd like to stay close asthese were my grandfathers tractors (both Bs) one of which my great grandfather bought new in 1946. I have the original pickup plow and single row culivator for it. My manual lift is in a different place, it is mounted on the torque tube right next to the battery box, it has a hydraulic lift for the plow,or did till I put the 3 pt. on. Thanks again and Merry Christmas to you both and to every one else here. Mike
Rod (NH)
12-24-2005 17:46:42
 Re: Question for Rod NH in reply to Mike in Ohio, 12-24-2005 10:08:38
Mike,
I am also rather sentimental about my B as Dad got it new a couple of years before I was born. I think the "manual lift" that you mention for the plows is really a depth adjustment, especially since you indicate that the plow(s) were hydraulically lifted. It sounds like you have the standard AC pick-up plow(s). The plows you see on my B are not AC - you can get a better view here:
third party image
Mine are aftermarket plows made by WIARD Plow Company in NY specifically for the B. They were a major manufacturer of horse-drawn plows during the first half of the 20th century. I have yet to find anyone who has similar B plows. They attach to the tractor very differently that the standard AC ones do. No hydraulic lift - manual only.
Take a look at my new post above titled "B Anchor Plate". If you want to attach some weight to your B front axle, make up one of those plates. You can bolt about anything to it for weight. Then, if you run across some standard cast AC wishbone weights, they will match right up to it. As I indicate in the post, even if you can find the weights themselves, you would really be pushing your luck to find that anchor plate also. The J bolts could also be fabricated from 3/4" dia steel rod and threaded to suit.
Rod
BCnT
12-23-2005 18:42:50
Mike, 'scuse me fer buttin in but if you want some front end weight for cheeep,heres what i did on my ford 2000...i got a piece of 4'' angle iron and cut 2 pieces 4'' long...i burnt a hole thru one side to match holes in adjustable axle and bolted it to axle and then welded a 3' piece of 3/4'' rebar in center of the flat sticking straight up and repeat for other side...i find those cheap concrete weight bench sets at garage sales all the time and i buy every one of em...stack them weights on when ya need em...they look like hell but they work good and ya dont need a truss to add or take off ;)
Rod (NH)
12-23-2005 17:12:10
Hi Mike,
And a very Merry Christmas to you also. Those front weights are stock Allis B weights, sometimes referred to as "wishbone weights" because they attach at the standard arched front axle. There are actually two of them that are installed back-to-back. I think they are about 80 pounds apiece for a total of about 160 pounds. They are a little difficult for one person in a sitting position to hoist them up into place until the attaching bolts are engaged. That's probably why there are two of them. I understand they are not that common and the few that I have seen sold are up to around $200 (not including shipping) a pair, if not more. I don't know where you can get any. As I remember, the last wishbone weights I saw sell was from someone in NY on ebay. Shipping charges can get high fast with weights like that. That becomes pretty expensive for adding weight unless you want to just pay a high premium for originality. There are also stock engine side weights that go on either side of the engine block. Those weigh about 90 or so pounds apiece. I think those are also pretty pricey but are a lot more common. You can see what those look like here: third party image
The side weights will not fit when the standard belly sickle mowing machine is in place but should fit OK for your rear 3pt mower. I don't know where you can get any of those either. They do occaisonally show up on ebay. There are also stock AC weights for the B that attach to the front wheels but I don't have any and don't know how much they weigh - I suspect they are similar in weight to the wishbone ones.
The B is light in the front and since it was not intended or designed for 3 pt hitch work, the lack of some kind of extra front weight becomes more important. The weights I have (both wishbone and engine side) are used when plowing with the B/C pick-up plows. I just leave the wishbone weights on all the time. They don't interfere with anything and they are kind of a pain to take off and put back on.
You can also add weight to the front tires themselves. A calcium chloride solution is common and has been for many years for that purpose. There are many that hate it but I have never had a problem in using it for over 40 years. My B tires aren't loaded at the present time but my Oliver has had calcium in both front and rear tires for over 20 years now. You just need to make sure you use inner tubes and replace the valve core every five years or so. A close eye on good maintenance will avoid rim rust problems when using calcium ballast.
Rod
