B Engine Block Crack Repair
Whiskers1949
12-23-2005 13:17:25
Well, I finally got around to tearing down my "42B. Pistons and cylinders look fine, but I noticed two small cracks in the block between the liners of cylinders 1 & 2 and 2 & 3. What"s the best way to fix this problem? I haven"t torn it all down yet, but it also looks as though the crank journals may have problems due to rust. Are oversize bearings available? Or, should I start looking for another short block?
TxAllisMan
12-25-2005 11:30:27
 Re: B Engine Block Crack Repair in reply to Whiskers1949, 12-23-2005 13:17:25
I have a 41 C which had cracks at the top and bottom of the liners and I did nothing to them and they have never leaked any. If they do leak use ceramic block sealer and you will never have any problems.
BushogPapa
12-24-2005 11:04:50
To clean up the crank journals, never use steel wool.. Use Crocus Cloth with oil... Rip a piece about the same width as the journal and wrap it around the journal with oil, and then wrap a long piece of Cotton Clothes line neatly coiled around the journal... Then, pulling each opposite end, spin the Crocus Cloth... It will polish like all get out, and not take any measureable metal off either.. You may have to do it several times to get it like you want it, but it is the way to do it.. On the cracks at the bottom....once you have the bottom end back together and are done down there, turn the block rightside up and carefully pour in through a hose, one pint of non-hardening Permatex (have the water jacket clean). That is, if you don't want to pull the sleeves, or even if you do, use the same permatex to install the sleeves.. Good Luck..!! Ron..
Rich Perry
12-24-2005 10:42:49
First time replying to a question on this forum and I can't even get the suggested website correct-so here is the corrected website:
Link
Sorry for misinformation
Rich Perry
12-24-2005 10:32:52
I have the same problem on 2 1939 model B engines with cracks on the top and bottom, I'am planing doing a air leakdown on the water passages on my 1938 engine which is still assembled and sitting on an engine stand-don't know what this will tell.
Back in June 2005 on this Allis Chalmers Discussion Board forum found this under "Topic: Cracked block" website talking about cracked block:
Link
Hope this helps and Merry Christmas to all
steve(ill)
12-23-2005 18:18:46
the cracks are no rpblem inf less that .050 inch wide, they will seal up with the head gasket. if big enough to get your finger nail into, you need to repair.--- the crank has shims on the bearing caps. you can remove 1 or 2 to get a few thousands tighter. depending on what you are seeing, you may be able to polish the journals with steel wool or sand paper and then shim back to size. couple small pits are no big deal. main thing is to have it round.
J. Schwiebert
12-23-2005 14:58:48
Are these cracks at the top of the block or at the bottom. If they are at the top, I would not loose any sleep over them. On the bearings, you are looking at undersize bearings if the crank is to be ground. Oversize bearings are an odd baall where the outsie diameter is larger than standard. The first application that comes to mind on that the small V-8 Cats. Questions/
arjay
12-23-2005 18:53:42
 Re: B Engine Block Crack Repair in reply to J. Schwiebert, 12-23-2005 14:58:48
What if the cracks are in the web between the cylinders\sleeves at the bottom of the block. I think that is where I have a small leak.
How can I verify this is a place that is leaking and if it is leaking, how to fix it??
bob
J. Schwiebert
12-24-2005 03:09:00
 Re: B Engine Block Crack Repair in reply to arjay, 12-23-2005 18:53:42
As mentioned below, it is a wet sleeve engine and you could also have an O-ring that has deterioted and is leaking. Take the pan off and put some coolant in it and see where it leaks. Questions?
Whiskers1949
12-23-2005 18:16:11
The cracks are on the top deck where the head mates to the block. I haven't pulled the liners yet... I may not choose to do so. I guess my next question is this engine a wet or dry sleeve?
JMCHAPMAN
12-23-2005 21:22:51
 Re: B Engine Block Crack Repair in reply to Whiskers1949, 12-23-2005 18:16:11
They are wet sleve. Very easy to replace with home made puller and then block of wood and a hammer.
